Old Warmoth neck with "Gibson" scale length
datamicke
Hi!
Do I need to move the bridge?
I have in my possession av very old Warmoth neck (30+ years) with the frets inserted like in a Gibson neck. The distance between the frets are the same as on a Gibson or similar guitar with 24,75" scale length. That is closer together than on an ordinary strat neck. However, when I insert this neck in the neckpocket of a Strat body, the distance between the nut and the bridge saddles are still 25,5"! Shouldn't the scale been changed to 24,75"? Maybe this old neck requiers the bridge to be moved a little closer to the neck? I know that the current line of conversion necks don't requier that but this is a 30+ year old neck so maybe this is different?
Attaching 3 photos. The unit on the folding rule is millimeters. Distance from nut to 12th fret is 12.2" (310mm like a Gibson) and from nut to back of heel 18.3" (465mm like a standard Strat neck)
Welcome to the forum and for your question.
That is not a Gibson scale conversion neck as they only have 22 frets and are designed to intonate with a normal strat or tele type body.
As it is a 24 fret 24 3/4" scale it is probably an early version of a 7/8 neck which is based on the same neck blank as a 25.5" scale but in order for it to intonate it needs to be mounted on a 7/8 body and your observations are evidence to that.
See this video for further info.
[youtube]https://youtu.be/WLLBquv-OD4[/youtube]
