As the pictures I posted show, I recent finished my LPS build. I have never had to do any sort of work on the nut on any of my other guitars, so I have a few questions. This may seem very amatureish, and if so, its because it is
When I tune up the A, D, and G strings, it seems like nothing happens for like 1/8th to 1/4 of a turn, then the pitch jumps and i hear a little <plink> sound. I assume this is because the slots in the nut are too tight. Is this correct?
If so, how do I go about widening the slots? I don't have any specialized sort of files for the job. Do I have to buy a set of files? I know one answer is "take it to a tech" but I don't want to. I want to learn how to do this sort of thing myself.
On a slightly different topic, I had some issues setting the intonation. A, D, B, and High E all intonated correctly. The A, D, and B saddles were all the way back before they did, but at that point they were nicely in tune. The High E intonated correctly with the saddle ruffly in the middle of its adjustment. The Low E and G string were a different story. On both of them they were still considerably sharp with the saddle in its rear most position. I took the saddle off on the High E and flipped it around backwards so that the edge that makes contact to the string was as far a way as it could possibly be and this got the string to a point where it was close, but still just a smidge sharp. I couldn't hear the sharpness, but I could see it on the tuner. The G string gave me pure hell. I ended up stripping the screw head while trying to remove it and ended up just screwing it back in with some needle noise pliers before I did any real damage (as I was getting highly pissed). Now the screw is so boogered up that I really need to replace it.
Where can I get a screw like that? Its not a normal screw, it has a bare spot where it rides in the bridge.
Is flipping the saddle a decent solution to get the extra adjustment I needed?
Is there something else going on which is causing me to have to intonate most of the strings all the way to the back of the bridge?
