rauchman
Greetings,
Was wondering about using a slightly smaller width nut vs the nut slot in an attempt to get more meat on neck on the outer sides of the E strings. Can one get a neck with a 1 11/16 nut slot, but use say the TUSQ XL nut cut for a 1.650" spread (assuming it's the next size down from the 1 11/16"). Kind of like using an R3 Floyd nut, where the string spread is a little thinner than the R4 nut. Or do the Tusq nuts come precut with different string spacings?
