Yes I have searched extensively, but I hope to get better advice here.
I am changing out my pick up covers (Thread on general board) and I decided I would try to mitigate the noise.
Mojotone 60th anniversary set pre-wired with a blender assembly. ( Middle PU rev wound)
Noise when not touching the strings, less when contact is made.
Slight hum in 1/3/5
Basement has Dimmers and LED bulbs, but no real difference seen when rotating or moving about.
Ground wire seems to be a good joint on the bridge.
Since I am taking it apart I will shield all of the cavities with copper foil, and solder the joints (not sure the adhesive is conductive)
Does this have a chance to help with the noise I am getting?
I don't want to replace all of the wires with shielded wires.
I also read about people shielding the inside of the covers, I would think that would kill the tone, but since 1/3-1/2 of the pick up is above the guard, I can see the temptation.
Slight hum in 1/3/5
