That's stupid!
All it is is a coil split switch (Note that they are using the nomenclature incorrectly. Standard humbuckers are not tappable, though a single coil with a center tap winding can be used here, if desired.) that varies the impedance across one coil, as well as a LPF. You can do this yourself for under $30.
