New Sustainer System in the market?
misterfinn said:
...and a more robust demo.
That was my thought. You can make any guitar feed back or sustain if you just let it hang in the breeze with everything turned up. Need to see what this system can actually do that you wouldn't be able to do otherwise.
Yup, would like to see it at work tracking through POD Farm with headphones, and how that mimics the interaction between a guitar and an amp.
I can get convincing results with the Sustainiac under those conditions in a way that will pass the blindfold test, more than I can with the Fernandes.  I'd be curious to see how this system performs.
Here's a demo from the NAMM floor:
https://www.youtube.com/watch?v=3ybUuPz44SY
Not nuts about the "distorted" sound he's getting, but I reckon it's a piezo system so that's what you get.
I don't get the impression the software development he contemplates has been done yet.
I'd love to see this technology re-visited and perhaps revised.
The one drawback in using this technology is that it uses the neck pickup as the driver.
I wonder if there is a way of triggering the vibrations in a different way, which this gentleman has just barely touched, by utilizing the bridge saddles, but also adding perhaps a driver that mounts in the neck or fingerboard itself, such as Epiphones NanoMag that they use in place of piezo's for thier acoustic sounds.
By having the sustain circuit tied this way, it would allow the neck pickup to be used, or actually any or all pickups, simultaneously or individually.
Take into consideration that the original Sustainiac circuit mounted to the headstock and wasn't reliant upon the magnetic interaction with the pickups to generate the sustain.
I know there are plenty of folks out there who would live to use this technology if it weren't for the fact that they can't use it on a neck pickup, or on #2 or #4 on a 5 way setup.
