Just got a new neck for a nice MIM Strat. With a new neck of this quality, it will rock! I own three Warmoths, but my usual helper is not available. So i'm on my own and feeling inadequate. But i am pretty good with my hands and I am careful.
The new neck has a partially closed-off truss rod slot. There are some wood burrs covering part of it. Plus the neck is a little rough in spots, so i'm sure some sanding is needed (in both cases?). Neck is roasted map with rosewood. It is a thing of beauty! Take a sharp X-acto blade to trim the burrs first? Or just sand that part done until they do away?
Plans are to leave it unfinished other than the headstock, which will get a decal and a light poly finish (satin probably) on the face only. Other Warmoths are TruOil, but non-roasted maple in each case.
Does the entire neck need a final sanding? I was originally told "no." But not from a reliable source maybe.
Best way to make sure the Gotoh tuners line up perfectly? I trust drilling a tiny pilot hole and maybe using some beeswax is a good idea? Any guidance for me? All advice welcome!
Neck will get a pro setup and final fret work prior to assembly, though my other three Warmoths got played for a while without that and were great. Fretwork on the new neck is amazing! SS frets BTW.
Thanks! Haven't been hanging here for a good while, looking forward to being back! Huge Warmoth fan, feel they hold up well to even my Melancon Pro Artist S (chambered Strat). And they are a Fender killer IMO - and that's from someone who thinks Fender is making their best guitars now.
