Hey Everyone,
I own a custom Warmoth Start with a black Korina body and pau ferro/goncalo alves 24 fret neck with side adjusting mechanism.
Its been with me for almost 2 years now and have always used 9-46 gauge strings. I decided to change to 10-46 gauge the other day and after I installed the new strings, I noticed that the action was quite high (obviously). I started messing with the bridge saddles, tried lowering the bridge, didn't do much difference. I went on researching about neck relief and how to fix it. I did the string test with the capo on 1st fret and measuring the gap on the 12th fret and noticed that there was no gap between the strings and neck. I messed with the relief from the side adjusting nut and it also didn't do much.
Next day I decided to go back to 9-46. I put back the strings on and the action was a bit off (since I messed with the bridge and neck relief). I measured the relief (with the method mentioned above), the strings were also touching the fretboard on the 12th fret. I decided to take off the neck and reset it using Warmoth's tip. After trying to make the neck as straight as possible, I noticed that the heel nut was almost loose, I don't know if this was the case before or if it's because the neck wood is pretty hard by nature.
So my guitar was playing nicely again yesterday but I'm afraid I messed up something with my neck. I will check the relief today. What do you guys recommend I do to make sure nothing is messed up?
I just need tips on how to make sure I have the proper relief, low string action, nut action, and fret leveling. What tools do I need? How can I achieve the best setup?
