Nameplate for an SG
Cletus
That's what I've seen them referred to as anyway. Between the neck pickup and the fretboard. Anywho, I'm buggered if I can find them. Anyone know where to get one?
Here's what I'm talking about. Cheers!  :help:
Hum, I'm not sure but I have a question myself: would it fit on a Warmoth SG?
I've looked all over the place, too. Can't find 'em anywhere. Looks simple enough, though. I gotta think you could get one made if you came up with a sketch and some dimensions.
eBay - this vendor will custom engrave what you want on it
http://cgi.ebay.com/SG-custom-neck-plate-/370340329516?pt=Guitar_Accessories&hash=item563a00f82c
Good man! Thanks very much.
Might wanna check your clearances from the end of the neck fretboard underneath, to the thickness of that little plate you want. It may also be partly obliterated by the 22nd fret on a Warmoth body/neck combo and underneath the neck, there may not be enough space to fit it under... :dontknow:
On the Warmoth SG, I think the pickups are spaced further apart from each other, putting the neck humbucker right at the end of the fret board like on an LP.
http://www.unofficialwarmoth.com/index.php?topic=11704.0
