Dan0 said:
			the ideal situation would have individual tone controls directly connected to the pickups and solid state buffers (active electronics, eww batteries..) with a resistor to set the input impedance then out put that to the volume controls. of coarse you could buffer the tone as well in another stage but most musicians seem to like the passive sound where the cap and pickup and pot create an lrc resonant circuit. but even then the purists would still prefer one of the quirky gibson setups.
While buffers are a good thing, their use also presents arguable compromises. (I'd say "differences," vintage purists might say "disadvantages.") I don't know just how audible the differences are in practice, but if you take a look at the application of any buffer to a passive guitar, there are a number of changes made to the behavior of the circuit. A buffer does not inherently change the tone of a guitar, but the pickups will each see a constant input impedance which is nearly resistive. (No complex part.) Since the input stage loading characteristics of the buffer are not subject to change, the resonant circuit between a pickup coil and its buffer will function the same through any amp/effect/DI/whatever, regardless of its input impedance or any other loading characteristics, and regardless of pickup selection. When two pickups are ran parallel in a passive circuit, great changes occur in the circuit as impedance, resistance and inductance drop and capacitance increases. In a buffered setup, the pickups do not run directly parallel, but rather, the outputs from each pickup's buffer are combined, much like channels can be combined on a mixing console.
Furthermore, though it can be compensated for with extra component choices, the lowered output impedance of the signal after buffering changes the behavior of the low pass filter which is usually created between the resistance of the pickups and the parasitic capacitance of your guitar cable. With the resistance lowered, the cutoff frequency shifts upward, giving a slightly brighter tone. Many people find this desirable, but then some people like their "dark cables." (As I understand, curly cables are popular for their higher capacitance.) You can adjust it to taste with an extra capacitor on the output.
Also, you might see a slightly higher impedance load against each pickup going straight to a buffer without the usual volume and tone controls loading you down. A couple of resistors and a capacitor can fix this, if you can hear the difference. :blob7:
Every possible way to wire a guitar presents some compromise to someone. It just depends what you find important. I think buffers can do great things for basses. They don't seem to appeal to most guitarists, though. In any case, I honestly don't understand why so many people find batteries horribly unappealing. EMG makes a few pickups with 80uA opamps. If you want to go the discrete FET route, you can get up to a couple of milliAmps. Not worth worrying about, as far as battery life goes. Plus, unplugging your guitar after you play is only mildly inconvenient. Then again, half the time there is no reason for anything fancy. Guitars are fine in the passive realm, when you wire them in a practical way. My preference is always for as few controls as possible, because anything else presents too many compromises.
