Superlizard
Now, this isn't something I'd be interested in doing, but perhaps some of you who own one would be interested in this particular mod.
Buddy of mine on another board decided to change a few op-amps in his 5005 for better tone... not unlike modding a stompbox.
As he says:
As he says:
I'm going to change out the op-amp in it. The original is a MC1458p. I've ordered a socket and a couple each RC4558p and TL072. Why a couple? Because I amp going to try stacking them too. I will try a pair of 4558s and will probably try a pair of 072s.
So I started with a pair of stacked 4558 chips. I decided to jump right into the stacked chips as I was going to have to solder all of these each time. In for a dime, in for a dollar. Laughing
Wow! Distortion is "more" and a bit smoother. Some more of that SS raspy-ness is gone. These op-amps (RC4558p) rolled off the highs. I can dime the treble tone control. Amp isn't overly bright. The down side is that the noise floor of the 4558's became apparent when I dimed the gain. The hiss turned to squeal. I upped a resistor inter-stage to try and tame it, but it really didn't help much.
On the the TL072s. These are a higher quality dual op amp. Now the treble is back. I can turn that down at the treble control though and it's great. The noise floor with these op-amps is much better. I returned that inter-stage resistor to it's original value. Now the amp has all kinds of gain and it's not as raspy as it was.
Very cool mod!!!
The chips are literally stacked one on top another and soldered together at the legs. This is something Dave Barber seems to have pioneered in the effects world. What you get is a lowering of input and output impedance from the parallel dual op-amps. In this case the amp got more drive and it smoothed the OD out a bit as well.
See the right side of this photo. This is the amp's PCB.
In retrospect I liked the tone of the 4558s better, but the noise issue was the determining factor.
