There are so many different types of MIM Strats, although you said Standard 2012, to be certain I would suggest to remove a tuner and measure the hole.
They are probably the type with two locating pins behind them so Schaller hole bore would work. But you would need to take care of making the holes for the locating pins.
http://www.warmoth.com/Guitar/Necks/TunerHoles.aspx
Ideally you might need one of these.
http://www.stewmac.com/Luthier_Tools/Types_of_Tools/Jigs_and_Fixtures/Tuner_Pin_Drill_Jig.html
But please take one of the tuners off and check which one you actually have.
