Steve_Karl
Hi there,
I've got 8 coats of Minwax satin poly on my mahogany body and it's pretty shiney right now.
I think I finally figured out how to use the micromesh set that I got a few years ago but I wanted to get some input on the whole process.
What I've been doing is targeting areas that are showing scratches or look slightly foggy.
Where the light bulb really turned on for me was with an area that had some scratches.
I kept going down to lower grits until I saw that I was cutting away the scratches.
Turned out I had to go down to 1,500 to see results.
Then up, up, up all the way to 12,000 and it looks great.
I was worried about 1,500 taking off too much finish and kind'a still am, but after I saw the results
I'm wondering ....
should I just take the whole body down to 1,500 and then up to 12,000 grit by grit,
or should I just continue to target areas where I see a problem?
How do you do it?
Thanks!
UPDATE:
Yea .... I think I've got it fugured out now. I took a fairly large section down to 1,500 and then back up to 12,000 and it's a whole lot like glass now but the finish is looking thin compared to areas that I haven't rubbed.
Gonna spread out from there and try more area and see how it goes ...
... but might want to scuff the whole body with a grey scotchbrite real good and then put one or 2 more thicker coats of finish on.
Might take a day or 2 but I'll report back.
UPDATE 2
Gray scotchbrite > taking it all down to where is *seems* like I'm getting below the imperfections that were bothing me, and I'm getting a consistent dull frosty look. Very similar to the micromesh 1,500 grit but a bit quicker to get there.
(Getting rid of little sparkely bits that seem to be lodged in the pores ... any thought on this ? would be welcome )
I say *seems* because I'm not sure if the frosty look is now just hiding what I didn't like or it's really getting rid of it.
I know I'm taking a lot of the finish back off, but not sure how much, and not sure if I'm going to have to put an other coat on, and if I do
(here's the real question in this update)
will I be right back where I started today with the micromesh, or will I be closer to a glassy smooth finish?
I'm wondering ....
How do you do it?
Thanks!
UPDATE:
UPDATE 2
