davehetfield
The best must-have equipment for a vacuum cleaner
Currently, the vacuum cleaner is a commonly used tool and has become an effective arm of housewives. Therefore, manufacturers have constantly upgraded functions and accessories to bring out the perfect versions.
The following article will introduce you to the best functions that a vacuum cleaner needs to maximize cleaning the house. With this article, you will be updated with information so that you can choose the Best Rated Vacuum Cleaners on the market for your family.
Smart functions required in a vacuum cleaner
Dust detection sensor
This is a fairly modern function and almost only appears in high-end vacuum cleaners. The device is equipped with a sensor that will help you know the cleanliness of your cleaning place. If the cleaning area is dusty, the sensor system light will illuminate until the area is completely cleaned.
Dust blower function
In addition to vacuuming, current models are also equipped with a dust-blowing function. You may feel a bit absurd, but this function will be very limited in some cases, such as blowing dust in narrow slots, falling leaves in the garden, or used to pump some necessary objects. Usually, the huge blowing force will help you blow some things easily.
Handle control
Top rated vacuum cleaners equipped with a handle control panel will bring great convenience. There will be full-function keys on the machine handle that allows you to turn on, turn off the device, and adjust the vacuuming power level to suit your needs without bending down to accommodate like traditional machines. This also makes house cleaning more comfortable and effortless.
Flexible rotating floor nozzle
With the 360° rotation function of the suction head, you can change direction flexibly when hitting obstacles. From there, you do not need to move much and allow to move the furniture in the house. Flexibility also works to easily clean dirt in hard-to-reach places such as under beds, tables, chairs, narrow spaces, or high areas like ceilings and car roofs.
HEPA filter and deep vortex function
Most high-end vacuum cleaners today have these two functions. Besides vacuuming, HEPA air filters also help you filter the air, dust, mold, and bring fresh air. This function is also extremely necessary for allergy sufferers with dust and dirt.
In addition, the ability to spin deep is also quite important. Depending on the vortex, technology will bring different effects. But in general, this feature can help control dust, limit hair clogging, and compress dust to save space in the trash can.
Besides the above functions, the accompanying accessories are also a very important factor. Depending on the structure, the vacuum cleaner will come with different accessories such as brushes, nozzles, crevice tools.
Of course, many high-end versions always have a built-in brush specifically for sweeping hair and hair. In addition, there are also car accessories, sofas. Therefore, you should choose the right accessories depending on your needs, avoid excess capacity, and waste home space.
Hopefully, with the above information, you have gathered more best vacuum cleaner reviews and can choose for yourself a suitable vacuum cleaner for your family. Thank you for following our article!
Handle control
