Ok I think I'm ready to pull the trigger. Again, I want to take everything off my MIM Strat and put in on a new body to lighten in up. I have decided to go with the Gotoh trem and have Warmoth install the posts. I am doing the universal route as I would like to have the option of putting a humbucker in the bridge at a later time. I also want no paint, as I can sand myself and I plan to use a danish oil finish with a very thin coat of polyurethane varnish on top for a natural look (I have done this on a lot of non-guitar projects). Here is the rundown:
Construction:
Chambered
Core Wood:
Basswood
Lam Top Wood:
Roasted Alder
Right / Left Handed:
Right-Handed
Control Cavity:
Top Rout
Multi Pickup Top Rout:
Universal
F-Holes:
None
Jack Rout:
Strat® Flat Mount Top Jack
Bridge Rout Type:
Tremolo
Bridge Rout:
Gotoh 510 Tremolo
Would you like Warmoth to install the bridge studs?:
Yes, from a bridge I have on order.
Mounting Holes:
Standard 4-Bolt
Neck Pocket Shape:
Strat®
Body Contours:
Forearm Contour, Tummy Cut, Custom Contoured Heel
No binding, no battery, no paint
I will wait a few days to order to see if anyone has any other suggestions. One more question I have is in regards to the core body wood. Basswood is economical, and lightweight, and will only be on the back. I prefer the look of mahogany, but weight is more important in this case. But given that the body is chambered, will there be much of a difference between basswood and mahogany? Is there another wood I should consider? And either way, can I pay extra to have Warmoth select a light piece of wood?
Thanks again for all your help!
