I have a Warmoth Jazzmaster body on the way and am planning out the build. I purchased a 920D wiring harness (will be dropping in Lollar gold foils) and want to clarify the grounding. Looking at the provided diagram, I understand the bridge ground, but I'm not sure about the "body ground". Can someone please explain how those would connect to the body?
Would I be okay with just the bridge ground, or is there added benefit to grounding at all three points simultaneously?
Thanks!
Thanks!
