Jazzmaster “Purple Beauty”
Highland89
Warmoth Jazzmaster
9.7 lbs
Body
Jazzmaster
Mahogany body
Flamed maple top
Purple satin finish with cream binding
Natural unpainted back
Body stained/finished in Tru oil
Contoured heel with offset neck plate
Hipshot bridge
Fishman Fluence classic humbuckers (direct mounted)
Neck
Stratocaster
Modern construction (double action truss rod)
Roasted maple shaft
Rosewood fretboard
Cream side dot inlays
Tiltback Stratocaster headstock with rosewood veneer
Standard thin neck profile
25.5 scale length
1-11/16” (43mm) nut width
10”-16” compound radius
6150 (med. jumbo wide) stainless steel frets
Earvana compensated nut
Hipshot locking tuners
You installed the Fishman battery pack I see - Id love to see inside the control cavity. Beautiful build.
How did you select the Earvana nut with the tiltback headstock option? I want to do this but doesn't let me configure...
By the looks of it he is most likely using an Earvana Gibson style nut which you can buy from Earvana.
In this case, wouldn't the scale length be off (as Gibson one would be intonated for a shorter scale length)?
I bought this guitar second hand from the person who put it together. It’s a Fender scale length. I know Warmoth doesn’t offer the nut with a tiltback so I’m sure he just installed it himself.
It is a compensated nut based on where the 0 fret or leading edge of a nut would be. It does not alter the scale length but compensates the relative position of the nut slots compared to a theoretical 0 fret. Note the nut is sold as a Gibson style referring to the nut shelf it fits on rather than it being for a scale length.
