BigSteve22
So, I got my paint booth set up. (Not exactly OSHA compliant, but then again I'm not doing a production run, just one neck.) Got a few coats of lacquer on it and let it dry for a day. The lacquer is really starting to bring out the flame.
Today, I applied the headstock decal. Twice. It was twice because I screwed up the first time. When Rothko and Frost says their decals are thin, believe them! Much thinner than any other decals I've ever used, anywhere. I was smoothing out the bottom edge, with a soft tissue as recommended, and somehow I tore off a piece. Not just a little tear mind you, it totally disappeared. Not a trace of it anywhere, GONE. So I grabbed a piece of painters tape, and with one quick pull, the entire decal was gone before it could start to adhere. Luckily, knowing that I can screw up at a moments notice, and not wanting to wait for a replacement to arrive from the UK if I did, I ordered several. Second application went well.
Rothko and Frost did a great job of making exactly what I wanted, and I certainly can't say they didn't warn me about how thin and easily damaged the decals were. My advice is that if you want a quality decal, made exactly to your specs, you can't go wrong with Rothko and Frost. Just buy more than one, the price goes down when you do.
Now I'll wait several days to be sure everything is completely dry, and finish things up. Photos attached.
