Hi there,
I'm struggling with working out how to wire my Warmoth strat - I've got a DiMarzio Cruiser and a Fast Track 1 to wire to a E-model Megaswitch, one vol and one tone (I know, it's a 2-pickup Strat...).
The instructions with the Megaswitch tell me how to wire the 7 points, and mention ground wires, hot wires and coil tap wires. DiMarzio uses 4-conductor wiring, with red, black, white and green wires. The DiMarzio instrucitons say that red=hot, green/bare=ground, and black and white should be soldered together and taped. This makes sense for normal humbucker wiring with normal switches.
So here's my problem - the instructions for the Megaswitch assign wires to the 7 points - I can work out which are the hot wires (the red ones) but points 5 and 6 should have neck pickup coil tap and bridge pickup coil tap respectively. But I can't find any explanation as to what this means. I'm guessing it might be the black and white wires soldered together and connected to the wiring point, but I don't know for sure.
Can anyone help? Many thanks!
