Installing a Floyd... neck pocket shim?
The Dali
Hi y'all - just a quick question.  If I'm building a Warmoth guitar with a floyd does the neck pocket need to be shimmed or can I bolt on and rock?
you should be good with just bolting on and going. warmoth automatically readies the neck pocket if the body is being routed for a floyd
if you order it for flatmount, the pocket will be angled, if it's recessed, then it's already good to go.  if you're flatmounting a body you've already got, then some extra elbow grease is in order.
