Hi Guys , :guitarplayer2:
I just recently order a neck and body from Warmoth. The guitar im assembling was based from Stratocaster.
I need some help from you guys, who have some knowledge in calculating the correct position of the Nut Slot for Fender LSR NUT in respect to the middle position of the neck
which is 12 3/4 (323.8mm).
What i know is the LSR nut has to be .219 (5.562mm) in width x .105-.115 deep @ center..
Im not very sure were to take the measure of 12 3/4 (323.8mm) in respect to the position of the slot width. I know this is critical to be able to achieve the correct intonation.
1. I know to get the correct intonation I have to measure from “12th FRET” a distance of 12 3/4 (323.8mm) towards the NUT and measure if from the edge
but this is the case if im using a standard nut. WHAT if the NUT is LSR and the NECK that i purchased is not "PRECUT"
2. Im not ver sure when i measure from the “12th FRET” a distance of 12 3/4 (323.8mm) towards the NUT where should I get the reference incase of LSR NUT?
Do still have to measure it from the edge of .219 (5.562mm) width? Or I need to minus .094 from 12.75 (12 3/4)?
I have some drawing i plan myself can you pls advise is this correct cheers!
I appreciate if you can advise me on this matter and I don’t want scrap the neck. :headbang1:
