Humbucker ring size
jackson929
Does anyone know what size the humbucker rings need to be for a V-R build?  I am having some custom built but he seems confused by the numbers I give him which are the cavity size?  Not sure what he wants for sure.  I measured the cavity  size to be 2 7/8 x 1.625.  So what total outside dimension do I need?  Just add .25" to this will cover the spring hole/cavity area?
Stew Mac lists their humbucker mounting ring outside dimensions as 3-17/32" x 1-25/32" (89.69mm x 45.24mm).
Thank you for the help.  And this size works for Warmoth humbucker cavities?
Those dimensions are for a standard size Gibson style humbucker. If you order the body routed for standard humbuckers, then that size should work.
I would think so. However your best bet, if you have doubts, would be to either call or e-mail Warmoth and ask them to be sure.  :icon_thumright:
