GratefullyRedd said:
:blob7: :sign13: :hello2: :icon_biggrin:
yes this is exactly what I want, now what do I need to make it happen?
You need a lot a switches and wire, and, to keep all the possibilities straight, one of those armbands NFL quarterbacks wear when they can't remember all the plays (actually, after thinking about it, I think I missed a dozen possibilities with 2 coils in parallel, wired in series with the 3rd).
But honestly, most of those possibilities are going to suck, as an HB with its 2 coils out of phase and/or in parallel is usually going to be pretty anemic.
If it were me, and I wanted a lot of just the most useful possibilities, I'd put a 3 way switch for the HB to give either one, the other, or both coils (in series with each other - standard HB style). Then I'd use a 5-way switch to give me either SC alone, HB alone, HB+SC in series, HB+SC in parallel in phase, HB+SC in parallel OOP. Or, a 4 way to give me SC, HB, HB+SC series, HB+SC parallel, and a push pull to change the phase of the SC (this way adds the series-OOP option that I, personally, would probably never use).
You can also look into those Seymour Duncan HB mounting rings with the mini switches for the 2 coils on them.
Of course we haven't even mentioned other options involving (passive) bass/mid/treble tone controls/caps/etc., and options for balancing the volume of the coils/pickups...
