Hello, I finally built my project guitar, but Im having some problems:
The problem im having is string action and buzzing.
The first time I put the guitar together the high E string was low and would play open, it played the first fret. So I put a shim on both sides of the nut(treble and bass side) -- Should I put it only on the high E side?
After that, the guitar played okay but my action was way too high. Over around 3mm on the bass side and around 2.5mm on the treble side(thats on the 12th fret).
I lowered the bridge and used the side adjuster and currently Im at 1.5-2mm on the bass side, but im getting buzzing ad super short sustain due to choking strings after the 12th fret. The side adjuster seems like it can go on more, because i left it a point where it wasn't hard to turn.
When I installed the neck I did NOT adjust the heel adjust(because i forgot...), but it seems like the neck was already straight. Im using the back cover of the body to verify that.
What should be the procedure to follow here?
I wanted to reset the side adjust but im not sure how to proceed. Completely loosening the heel nut means taking out?
Thanks for your time.
- Offset V body with recessed Wilkinson tremolo cavity
- Warmoth Pro neck with 22 frets and LSR roling nut
