Why not another Area or another p-rail then, just for consistency? I'm sure one of the four p-rail options will have what you might call a "balanced" tone. Those area's are great pickups too. Your talking blackfaces, so single coil type sound works real well there. I often find humbers a bit boomy in the bass end when plugging into that sorta amp so another area may be what fills the bill...minions said:Well a single coil would be fine, but it doesn't much to me, since I ordering this guitar custom from Warmoth, as long as it gives me the proper tone. The main thing I'm looking for is a balanced tone, which the Seymour Duncan Five-Two claims to give.
I want a nice balanced clean tone that will sound clear through a Blackface. Something that's not too crisp or not too crunchy. As for who I want to sound like, well, think of Jimmy Page's clean tones, although I know a lot of these are done on an acoustic. As I told someone else, I'm looking for my own sound. In the bridge of this guitar I'm putting a Duncan P-Rails and in the middle I'm putting a DiMarzio Area '67.
rockskate4x said:Why not another Area or another p-rail then, just for consistency? I'm sure one of the four p-rail options will have what you might call a "balanced" tone. Those area's are great pickups too. Your talking blackfaces, so single coil type sound works real well there. I often find humbers a bit boomy in the bass end when plugging into that sorta amp so another area may be what fills the bill...minions said:Well a single coil would be fine, but it doesn't much to me, since I ordering this guitar custom from Warmoth, as long as it gives me the proper tone. The main thing I'm looking for is a balanced tone, which the Seymour Duncan Five-Two claims to give.
On my amp, I turn the bass down a ton to get the sound right.rockskate4x said:I often find humbers a bit boomy in the bass end when plugging into that sorta amp so another area may be what fills the bill...
I was waiting for that... even so, to a certain extent there is an amount of equing that you can't always do. If I want a nice round bottom to the tone turning up the bass might do that... or it might make the guitar sound boomy. If I want nice bell like highs, turning up the treble might do that, or it might make it thin and hissy sounding. If you know that it is a good amplifier but you are still not getting the sound you like even with your eq changes, you find pickups that do the job better. In my experience, fender type amps sing better with single coil or other low output pickups. I do not mean to say, however, that you should only use single coil pickups in fender amps. Because as we all know there are many many musicians who get the sound that they like by breaking the rule that our friend Jerry tried to establish earlier.Max said:On my amp, I turn the bass down a ton to get the sound right.rockskate4x said:I often find humbers a bit boomy in the bass end when plugging into that sorta amp so another area may be what fills the bill...
Ha, it's what the knobs are for.
