R
Rouse
Heres the picture:
Its a SD Seth Lover. It says 1.956 inches on the meter. I know F-spaced is 53mm, this says that its 49.682mm, which seems to be gibson spaced. I just wanted to double check that the guy who is selling this measured in the right spot. He measured towards the middle of the poles, do you measure there or on the outside? If it was on the outside, it might be closer to F-spaced. I asked the guy and he had no idea.
