:help:
Hi all new to the forum as I will be attempting my first Strat build shortly (body and associated hardware should be here Tuesday ordering pickups on Black Friday I hope and the neck after that)
I bought normal strat wiring kit from stewmac im comfortable with the layout and the general concepts of what im going to be doing to wire this thing up but....
im still a little lost onl how things are grounded.....mostly because there seems to be a lot of conflicting info on the net regarding this.
Do I need to ground the backs of all the pots together? I am using this diagram as my guide as my first crack at this is going to be some Duncan Vintage rails.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=duckbuckers_vintager
The diagram above seems like they have the back of all 3 pots interconnected. Then I see diagrams that don't have it. Im also not 100% sure where I connect the ground wire from the trem claw. I'm running under the assumption that I connect the trem claw to the back of the volume pot also but if that's not correct im open to advice. :toothy10: Havent had the chance to crack open one of my stock strats to see how things are so I figured I would ask.
