I read somewhere that, instead of shunting to directly to ground in a coil tap situation, you ought to put a .047 or higher value cap between the start / finish wires and the ground. That way, in theory, you get the bass coming through the tapped coil. This should 1) reduce hum, maybe by a lot since most of the power is in the bass frequencies anyhow, and 2) lessen the "thin & crappy" sound problem of most tapped coil setups by adding in some bass response and increasing overall output, while still giving you the treble aspect of single coils.
I'm curious to try it since I like to tinker, but has anyone tried doing it this way, and what were your experiences?
