Ground Wire on Hardtail Strat Build
guspac88
I'm building a hardtail strat with the Fender American Standard Flat Mount bridge and am completely unable to find these two pieces of info:
1) Do I still ground everything to the bridge if it's a hardtail? If so, where does the wire attach to the bridge?
2) If I select routing for that bridge, will Warmoth rout some path to get a ground wire from the control cavity to the bridge?
Thanks!
Run a bare wire to the bridge and just let it make contact with the metal of the bridge. Every Strat body made should have the wire hole already drilled.
