I think so because the strings also touch the block and stuff. But that is a good question, do the graphtech saddles conduct electricity?bpmorton777 said:are you still able to ground the strings with graghtech saddles?
Brian
RexTheDog said:I replaced them with graphtechs and i havnt broken a string there since. They also sound warmer and i perceived a slight increase in sustain.
back2thefutre said:I think so because the strings also touch the block and stuff. But that is a good question, do the graphtech saddles conduct electricity?bpmorton777 said:are you still able to ground the strings with graghtech saddles?
Brian
Dude, good question. I was going to put graph tech tusq on my next build with a fender hardtail bridge. It may cause problems though so maybe I won't...bpmorton777 said:what about us guys with the hard tial bridges?
Brian
See above ^^^back2thefutre said:Dude, good question. I was going to put graph tech tusq on my next build with a fender hardtail bridge. It may cause problems though so maybe I won't...bpmorton777 said:what about us guys with the hard tial bridges?
Brian
Does anybody know a definite answer on this?
I don't have a Tele, but I have a hardtail strat and all of the strings touch the bridge plate so it would work. But that seems kindof too iffy for me. I don't think I will do it. Ahh what the heck I'll just do it cause graphtech saddles are too cool not toSuper Turbo Deluxe Custom said:They are non-conductive, so if the saddle is the only thing between the string and the bridge, no grounding. On a Strat it's no issue because all of the strings anchor in the conductive trem block which is attached to the spring claw. On a Stop Tail T-O-M, since the strings are grounded through the conductive Stop Tail, it's also a non-issue. On a Tele however they are anchored into the ferrules which are not grounded because grounding occurs through the bridge (and bridge pickup with copper plate and screws connecting to the bridge plate from pickup or other similar type jumper). They would get to the strings from the plate through the saddles, which if graphtech are non conductive. But, most of the strings usually touch the string-thru holes on the bridge on a Tele.
