Gotoh aluminum stop tailpiece fits warmoth LP ?
Ang3lus
anyone knows ?
i can't find any info viable information on that unit
found something:
The tailpiece, however, will fit any stop bar tailpiece with a 3 1/4" stud spacing if you reuse your existing studs. Impeccable Gotoh quality and worksmanship as usual, another example of why they make parts for some very serious brand names.
hmm, what does 3 1/4" means ?
warmoth pockets are 82mm, that's what i know
DocNrock
There are 25.4 mm in an inch.  That comes out to 3.27 inches.  Pretty close to 3 1/4 if you ask me.
GoDrex
I don't understand the question since Warmoth routes for the Gotoh TOM.  :icon_scratch:
82mm = 3.23 inches - which is pretty much 3 1/4 inches.
tfarny
I believe it's the standard size. I'd assume it will fit - same maker, same basic idea, same attempt to be cross-compatible. you're talking about 0.5mm on each post, it'll work.
NonsenseTele
1mm is not gonna fit  :icon_scratch:
+1 to Gary "GoDrex" statement!
It's 82, our good friend Doc Brent missused 83 instead 82...
jackthehack
Note that the studs/inserts supplied with Gotoh and some other bridges from various sources are not always the same size as the stock routing that Warmoth does for the inserts....
