The Clear Satin Nitro we use for necks is nitro lacquer. It is soft (relative to poly), and will polish up to a gloss with use. The Clear Gloss finishes are poly.
The same finish that is sprayed on the back of the neck is also what will cover the fretboard on Maple necks.
The Satin finish we use for bodies is NOT the same finish we use for necks. For bodies we use Satin poly, which is very hard (relative to nitro). It should remain Satin for a loooong time.
And because I can already see the question forming on your lips: we aren't using the Satin poly on necks because it is extremely expensive. On bodies we are able to balance the added cost with the labor we save on polishing and buffing. It doesn't work out that way on necks, so we are continuing to use the satin nitro for now.
