Hi from Denmark, Europe :icon_smile:
This is my first build thread here, but my fourth Warmoth build... For background on this G4 body, see this thread: http://www.unofficialwarmoth.com/index.php?topic=21961.0
So basically this G4 body was a returned item, walnut body with black korina top ... and then for some reason a customer wanted it painted gloss black, and then returned it. So it was sitting in the showcases for just $199. Too good to pass up, it's now here in Denmark and I'm working on removing the black paint. It's a tedious process because there is both the black paint and under that several layers of clear coat. The paint remover that I found locally could work on the paint, but not the clear coat, so I'm sanding that off. Takes some time, but I'm getting there...
Some weeks ago I ordered a neck, not knowing that I would end up buying that black G4 body. I simply could not resist this piece of Pau Ferro fretboard wood, so I ordered a neck with it. The neck is on it's way over the pond right now, will update with pictures. It's a basic maple neck shot with a satin clear finish, and I have opted not to get dots on the fretboard. I want this piece of Pau Ferro to shine...
The body will get a tung-oil + wax finish once I get the last of the clear coat off.
When I bought the oil and wax I also bought a sample set of 9 different dye colors that can be mixed up with the oil. I'm debating with myself if I should add a bit of color to the Black Korina top (not to the walnut body). I'm thinking about adding a tiny bit of orange, red and black dye to the first coats of tung oil on the black korina top to give it a bit more ''warmth'' to better integrate with the Pau Ferro fretboard. Or maybe it's actually a great combination with the slightly more ''yellow'' of the Black Korina together with the warmer colors of the walnut body and the Pau Ferro fretboard. I'm really unsure about this and will not do anything stupido before I get the neck and can see it together with the body. Pics to follow...
Has anyone used tung oil with a bit of dye in it? Maybe even on a black korina top? I would really appreciate any advise on this... Thanks :glasses10:
