W
weezingthejuicebodhi
Hey guys,
Figured this is always the best place to ask since there is so much experience here.
As some of you know I just finished up my Strat and I love it so far. After some doodling I was finally able to get it in 'pretty good' playing shape but I'm still having some [nitpicky] issues.
It really comes down to string buzz all-and-all. At this point it is the only remaining bugaboo to deal with.
Things to know:
* Standard 25.5" body and neck
* Eb tuning, .009s
* Measured the neck relief @ 7th fret (w/ capo on 1st, finger on 17th) .012" per the good book of Erlewine
* Pickups were too high, set them as close to 3/32->1/8" as possible given the staggered pole pieces. Regardless of taste they definitely shouldn't be doing any 'pull' now
* Raised the string height a good portion. Before I'd say they were close to 4/64" (1.5mm since I usually measure with a ruler here) @ 17th fret - crown to string bottom. I see that this is the 'Fender Desired Factory spec' but no way. I juiced everything up to ~2mm.
With all of these changes (notably the saddle height change) I now have minimal/no buzzing. I still get the sneaking touch of buzz here if I hit something pretty hard or do dramatic vibrato. Since I'm playing .009s the higher action isn't a burden at all to me (still comfortable), but I can't help but shake the notion I could do better.
So with that said - is fret leveling the next realistic step? I can see by sighting down the neck there is definitely some opportunity. Since I won't be pulling/replacing frets is the a fairly safe DIY project to venture into? Any words of wisdom? Anything else I may be missing that I should be trying first?
Things to know:
* Eb tuning, .009s
