Fluid tip size and other spray gun questions
chubs
What size tips do you use on HVLP gravity feed guns for spraying nitro lacquer?
I'm going to have to buy a gun, any suggestions? I think for guitars a smaller touch up gun should do the job, I can't imagine you would need any more paint that what will fit in a 125mL cup, I've been looking at Devilbiss SRi Pro, SATA minijet 3000b and Iwata LPH80, any other suggestions or advice would be great.
I use a 1mm that seems to work out well.
As for guns, I'm no help. I bought into an Earlex HV5500 Spray Station, which is pretty much an all-in-one solution.
Works really well. I'm happy with it and the results I get.
Been doing lots of reading, and leaning towards the devilbiss SRi Pro, I think I will order it with both 1.0 and 1.2 nozzles and see what works best for me. There is no point in me getting an all in one unit, I already have a good size compressor.
Chubs I have 4 Devilbiss guns 1 is gravity an older GFG from the mid 80's its not HVLP
but what I like about  Devilbiss is the parts availability & compatability with other models
(that was the case back then).
Needle wise on the GFG I have a .9 fluid tip & needle set & you could almost sign a
cheque with it I think it is too small.
I use a 1.4 for  most gravity gun use, but being able to change set ups for different
viscosities ( rate of flow of a liquid, or how thin it is) this is what makes a good gun, you
can change parts & get parts.
There is recommendations on compressor size discussed here & there on the web but
again a manufacturer that has parts availability is key for me.
Different Air caps use different amounts of air so if your compressor can only put out a
lower amount of air  maybe there is an Air cap to suit you, maybe in 12 months time
you will have other gear that uses more air & you can upgrade.
If you use air nailers & sanders & oil those tools NEVER use the same air line, a moisture
trap & regulator are good & not to expensive investments.
& YOU, Lacquer & there variants are not only FLAMABLE they are EXPLOSIVE stay SAFE
& protect those lungs hardwarwe stores don't sell spares, wear a suitable MASK.
On the cup size 125ml sounds a little on the small size but it would spray a body no prob
You can mix more lacquer ia a larger cup like this.
http://www.devilbisseu.com/en-gb/product/mc-1-k50
& filter it into the gun with this,
http://www.sagola.com/index.php?zon=car&pro=15&num=7
pics are for reference most auto supply stores should carry these.
