Fishman recently released a bass version of their popular Fluence series as soapbar pickups for 4 and 5 strings. They are popping up in some retail builds, and the pickups themselves are available for pre-order from some places, but I haven't seen an official release date. I am totally sold on these things and am planning my first Warmoth build to use them.
Here's a review of the 5-string pickups on a Schecter SLS Elite:
[youtube]https://www.youtube.com/watch?v=yzoOfz2uZDk[/youtube]
I'm planning on a 4-string build on a 32" medium scale bass. I couldn't find the dimensions listed anywhere on the Fluence pickups, but they sent me a spec sheet over email. They are super close to the EMG 35, so that route should work:
The Fishman's seem close enough to be able to work in the EMG route to me. I only checked the 4-string specs.
The demo videos I've seen have used 4 pots and the 3-way switch for their controls, but I think I'd go with the 2-band dual concentric EQ. Warmoth will drill for 4 controls on the Short Scale G4 body, but I'm going to plan on using 3 and leave space for the toggle switch. I'm thinking volume (push/pull) - blend - voice switch - dual concentric EQ.
One thing I'd like to do is use the Fishman rechargeable battery pack, but I'm not sure there will be enough space in the control cavity. Here's a video of someone else installing one on a guitar (skip to about 1:13):
[youtube]https://youtu.be/l5pWmclavac?t=73[/youtube]
I imagine it would be pretty tight in the control cavity to try to squeeze 3 pots with wiring, a 3-way switch, the output jack and then this battery pack and charging port. The build would look a lot cleaner to me if I didn't have to have a battery box put in, but we'll see.
Anywho, I'm excited about it. I needed to do a little research to see if there was a way to make them work in a Warmoth build, but it certainly looks promising.
EMG 35 | Fluence 4 | WM EMG 35 Route | |
W | 3.5"/88.9mm | 3.515"/89.29mm | 3.58"/91mm |
L | 1.5"/38.1mm | 1.492"/37.89mm | 1.56"/40mm |
H | .880"/22.3mm | .811"/20.59mm | .75"/19mm |
