fatfingers
Hi,
I'm working on my first build - I have a standard tele body (black), "F" logoed bigsby, tortoise guard, and I'm waiting on the neck:
Headstock Telecaster®
Construction Warmoth Pro
Orientation Right Handed
Shaft Wood Purpleheart
Fingerboard Wood Figured Zircote
Nut Width 1 11/16"
Back Contour Fatback
Fretwire 6130
Tuner ream Schaller (25/64", 11/32")
Mounting Options Standard 4 Bolt
Fret Number 22
Radius 10-16" Compound
Inlays Abalone Face Dots
Nut Install Earvana GraphTech Black TUSQ XL
Scale 25-1/2 in.
I have a couple of questions on the build -
1) The neck will be predrilled, but the body is not. I read somewhere about cutting four screws to the right length and putting them in the neck holes with the point sticking out, then setting the neck in the pocket so you could drill the holes in the right spot. Will that work? Has anyone tried it?
2) I'm guessing that I set the neck first, then do the bridge, so I can make sure the scale is right, but I wanted to double check - is this the way to do it?
3) Thinking about putting a humbucker in the neck and tapping it. I've never had a guitar with a coil tap - will the split coils sound as good as a real single coil?
Thanks!
Nut Width 1 11/16"
Fretwire 6130
Fret Number 22
Scale 25-1/2 in.
Thanks!
