jbavier123
Hi, I've known about Warmoth for awhile but just recently have decided that I want to try and make my own build, but I have some questions before I order all the parts.
First let me start off with this, I plan to use an Explorer body with mahogany wood. My main style is hard rock and metal. If there is any more info you need before you answer the questions feel free to ask.
1. I'm confused on the whole top laminate concept, does it really matter which I choose if I just want the guitar to be black?
2. If I get a chambered body will I have to use a pickguard?
3. What is the difference between Humbucker (Neck) and Humbucker (Wood Mount) (Neck)? Same question applies to the bridge position.
4. What controls would I need if I am getting two humbuckers, neck and bridge? I would like to be able to turn down each individually so I am guessing two volumes, a tone, and a toggle?
5. Can someone explain the difference between the sizes of the Input Jack Rout? I have tried reading over it and it seems like it doesn't make a difference.
6. What is up with the stud install? I don't understand what this is at all.
Those are all the questions I have regarding the body for now, I'll work on the neck later. I'm sorry if some of these are stupid or obvious questions but I just really want to make sure I do everything right because this is my first time building a guitar.
Thanks in Advance! :icon_biggrin:
-Justin
-Justin
