Finishing up micromesh grain & coats (Tru-Oil) on Black Korina body
ztbishop
I'm currently doing a tele build (strat is just for reference on what I'm trying to match in terms of finish).
I'm finishing up a tru-oil finish on a Black Korina body / Roasted Maple neck. I've done 6 coats so far, with the neck thinned 40% mineral spirits after the initial coat. (Body is straight tru-oil). This is my first Warmoth Build (2nd build overall). I included my first build (strat type) which is about the sheen I'm going for; the strat is pine. I used a blow torch and tru-oil. I feel like the strat took 30+ coats because I didn't know what I was doing and wet sanded with mineral oil too often, washing away much of the finish in between coats.
I don't plan to go mirror finish, more of a satin similar to the strat (easier to maintain anyway). After 6 coats, I think the body is looking good so far, other than the grain not being filled. I don't really want to do 30+ coats to fill it in if it isn't necessary. I'm looking for some advice on the following ideas.
1. Use some micromesh now, and possibly a few more coats of thinned down tru-oil with mineral spirits.
-or-
2. Keep going on the body to fill in the grain
When I use the micromesh, should I go dry if I'm using 12-30,000 grit (especially on the neck) Or use mineral spirits for lube after a couple days of dry time?
For the body, I'm hoping a buff will take care of some of the glare in the grains (they tend to sparkle a bit since they aren't filled in) - but it's not a huge deal; only if the light hits just right. I didn't really want to do a mirror finish due to a.) too much work, and b.) I don't want scratches to stand out.
If you open the T_Body image, you will see what I mean when I have the light reflect on the grain... I'm not sure if micromesh would really help since it'll just buff the smooth outer body.
I'm thinking I could wrap it up over the next week and give it a couple weeks to cure.
Wow, what a stunning guitar body!
I have to get a black korina body at some point. IMHO, the color variations of the grain make it my fav' wood aesthetically.
Looks phenomenal to me.
I recently went through tru oil hell on a walnut-over ash body. 30 plus coats also. My mistake was wet sanding too aggressively (I used tru oil to wet sand but it’s so easy to burn through your coats). I ended up using the armor all method in the end, but I think what really got me the good results was skipping the coarser sandpaper passes and starting with 1500, then 2000 grit sandpaper. It came out far, far smoother to the touch than my factory poly and nitro guitars. I can’t get over how pleasant it is by comparison.
I also bought micromesh to go finer but never ended up using it, pronounced it done a day before the micromesh arrived.
Good luck to you!
I just sanded out a korina body. !3 coats of truoil and the grain still showed the pits like a polished golf ball. I'll grain fill this time.
