CtheHammer
So I recently started this thread to show my new flame maple tele body and neck that came less than a week ago from Warmoth. Now I am working through the scraps to figure out what works and what doesn't for applying dye to figured maple and am interested in the thoughts, comments, and ideas of all the fine folks here.
What I've got so far is red and black trans tint from Woodcraft and I've used lacquer thinner as my base that I've added the tints to. I'm using scraps of old t-shirt to apply the dye. The scrap I've got (also from Woodcraft) is very thin (next time I'm going to go thicker) and while it has some figuring it generally requires looking at the wood from the right angle in order to actually see it. I have applied water to the scrap and sanded the grain smooth using 220 grit paper on a sanding block.
Here it is after the first application of black dye:
Second coat and at an angle to better show grain (it is actually much darker but at this angle is reflecting the light over my kitchen table):
After sanding back:
After the first coat of red dye:
Last shot is in different light (kitchen vs kitchen table)
So here's what I'm wondering:
-The lacquer thinner seems to be drying pretty well, but I'm not sure if I am letting it dry long enough. I did all of this this evening over the span of probably about 5 hours. Should I be letting each coat of dye dry longer?
-Should I sand back the black more? Where does the balance lie between cutting out most of the black without going too far into the black in the grain that you want there to make it "pop?"
-I'm planning on going over the red with a few more coats; will that address some of the vagaries in degrees of red-ness that I am seeing right now after one coat?
Other note for those that may be wondering:
-For mixing the lacquer thinner with the tint I used the highly scientific "guestimate method." I measured out about 1 oz of thinner into a small plastic container (is plastic a bad idea? I'm using the microwavable tupper-ware-like containers that picked up at Wal-mart for $2) and then added 30 drops of the tint and then mixed. While the tint is recommended to be mixed at a ratio of 1 oz of tint to 1 qt of base liquid this seemed to yield a mix that would get me a tint that was pretty true to the red and black I was trying to get.
Thoughts? Comments? Suggestions? I'm kind of making this up as I go along so I'm quite open to input that can smooth this process out where possible. Thanks!
C
After sanding back:
C
