Fiesta Red Strat for shyboy999
Tonar8352
I just received this roasted alder body from Warmoth yesterday to finish in vintage style Fiesta Red for shyboy999. If you want to watch it step-by-step check in on my Instagram page @greggrubaugh. I will also post progress pictures here along the way.
I'll follow along on this. Since finishing is my weak point, I enjoy seeing it done right. Fiesta red will look good.
Curious ...
Can you do a close up of how you affixed the handle to the body?  I see the screws on the front.  Or maybe I should be asking how did you affix the handle to the body?
Also, what did you use to cover up the inserts?
I've got a build coming up and I like this handle method.  Makes sense.
Thanks
The hype is real  :party07:
Look at all the lonely parts waiting for a home...
I covered the inserts with painters tape and then cut around the inserts with an Olfa Cutter.
I use regular neck screws and then a toothpick as a wedge in the body hole. You can see how they wedge tight but the toothpick is soft enough that it does not distort the hole.
shyboy999 sent me some final assembly pictures of the guitar. I really like how it turned out!!
