swarfrat said:I'm guessing but I expect you're experiencing buffering. An unbuffered passive pickup into an amp probably has a 68k-220k load. Going into an opamp buffer it essentially has no load. They have crazy high input impedances.
Cagey said:I'm just guessing here, but if the "off" position ends up being a bypass (which is quite likely), then I would fully expect it to leave the guitar sounding brighter than you're used to. Some folks even use "no load" pots or eliminate the tone control altogether to get that effect on purpose, as even a tone control turned up to "10" will still bleed off some high end.
Cagey said:Manufacturers, politicians, and little kids often say things designed to absolve themselves of any responsibility. I'd be suspect, too.
When I said "bypass" position, I meant more along the lines of "take the thing out of the circuit", which in the case of a tone control usually means opening the circuit altogether, not shorting it out. So, the EMG tech may be playing word games depending on the terminology you used to describe your problem. If you used the word "bypass", that's his out. it would be nearly impossible for the problem you describe to occur.
I don't think the thing is defective, but not having such a device handy I can't say how to mitigate the effect you're getting. Depending on the design, it may not even be reasonably possible.
I will say this, though. As I mentioned earlier, a lotta folks actually purposely work at getting the effect you're getting because it's not necessarily a Bad Thing. You may want to live with it for a bit, and see if it doesn't work out for the better for you. It may just take some getting used to.
swarfrat said:They have crazy high input impedances.
swarfrat said:Judging from http://www.emgpickups.com/exg.html#info
I'd say it's a summing amp with a 250k input summing with a fixed notch at 950Hz and 20db gain. That'd be my first stab at copying it. 250k should appear for all practical purposes like a volume pot, and shouln't be overly bright. Sounds like the pot isn't taking it all the way out of the circuit.
