Hey.
I have a bit of a problem that I want to hear you peoples thoughts on.
I love the strat that I built a few years ago- ash body with canary top, canary neck with ebony fingerboard. Gorgeous guitar in my opinion
However I've always been unhappy with the sounds I get from the low e string. It sounds kinda dull and lifeless. (A bit like saying beow beow).
Like I mentioned, it's a canary neck with ebony fingerboard, stainless frets, earvana nut and callaham bridge.
The problem is still there when I fret the string, so I believe it's not the nut.
I tried changing pickup height - didn't help.
I've messed a bit around with the saddles on the bridge, and generally people only say good things about that bridge. One note - the holes in the bridge didn't line up completely perfect with the holes in the body. I think it amounted to about 1mm off on each outer hole. I did file a bit of the holes in the bridge so it didn't bind that much. However I also tried fixing the bridge with strings, so it was stationary on the body - in my mind this should negate any problems that could spring from the bridge binding on the screws.
Anyways, nothing I tried with the bridge seemed to change dullness.
I've tried changing the neck relief, also no change.
Changed strings a few times - still dull.
Btw, it's a modern neck with the side adjustable truss rod.
Any thoughts on what more to try?
Regards
Anders
Regards
Anders
