Greetings all,
I am building a 6/12-string doubleneck, and just got the wiring done last night. I've wired a few guitars with no problems in the past, and am pretty comfortable with a soldering iron.
I'm more or less copying the Epiphone version of the EDS-1275 (which has a separate pup switch for each neck). I looked around and found a few wiring diagrams, but ended up "doubling" Seymour Duncan's "Two Humbuckers, 1 Volume, 1 Tone, 3-Way Switch" diagram and connecting the hot leads to a third 3-way switch. I mangled the diagram to show how I did it:
Note - I did NOT connect the green & bare wires from the pups to the pots. I connected them to the ground on the pup switches, and connected THAT to the pots, so the picture isn't entirely accurate. And I only had .22mF caps available, not .47mF. But the tone seems OK.
In all, it works, but there are a few minor problems that I'm hoping someone here can diagnose.
1. Lowering either volume pot affects both necks.
2. When both necks are active, the output (volume) is significantly reduced. I imagine this is related to #1.
3. On either neck, there is a lot of hum unless both pickups are active. I figure this may be a grounding issue, but putting my hand on the bridge has no effect.
I wonder if there's a better way for me to wire the guitar... Please let me know if you need more information. Thanks in advance!
