Digital Nut Slotting Gauge - Generic - $65.06 delivered
Steve_Karl
Hey there,
I bought one of these "generic" digital nut slotting gauges - total cost with Pennsylvania tax was $65.06.
eBay - Digital Nut Slot Gauge
It's great! No complaints at all. It uses an LR44 button battery.
Battery compartment was initially not easy to find - but it's on the top under a little plastic cap that pulls out like a SIM tray for a phone.
When looking from the front of the gauge it's the one on the top left. The other slot on the top right seems to be a USB port - probably to run it without a battery.
0.000" or 0.00mm. It has a detachable brass base. It also comes with a plastic carrying case / box.
The buttons are solid and reliable.
So for those of you that ~might~ not know how this tool works - it actually measures the distance from the bottom of a string to the top of a fret.
So, to get an idea of the nut slot depth you measure at the first fret - but you can use it at any fret.
It took me a bit of practice to get accurate repeatable results but that was just about learning how to use it - keeping it steady on the fret board and making sure I don't move during measurement. I've found it a good idea to do about 6 attempts per measurement looking for the same result at least 3 times in a row.
I suspect my technique will get better with more practice.
And ChatGPT says:
"In inches, most of these indicators read in 0.001 in steps.
In millimeters, the same gauge typically reads in 0.01 mm steps.
Those two are equivalent because:
0.001 in ˜ 0.0254 mm
0.01 mm ˜ 0.00039 in
So while both scales are usable, the mm scale effectively gives you a smoother, more precise feel for tiny changes since each step is about 40 % of a thousandth of an inch.
Use the 0.00 mm mode for the highest resolution."
That's all for now ~
I've got the stewmac version of that thing and love it. I second that it takes some practice and patience to get good readings, but once you've got it down- way better than squinting at a string action guage or messing with feelers.
I agree with TimewNewRoman - way easier and more accurate than feelers or rulers.
After measuring 6 of my guitars - I'm realising that I bought this mainly for my education - trying to discover why one guitar feels and plays a certain way - relative to the others.
I'm sure now that I'll never try to make all the strings sit the same measured distance from the first fret.
I've always done my nut slots by feel - and will continue to do so.
It's just nice to have a reliable measurement also.
