After planning to get everything over to my friendly neighborhood luthier, my car's cooling system decided to take a nose dive, so I've been light on funds. That made me get a little brave and willing to tackle things I wouldn't have otherwise, and since most steps are pretty intuitive and Warmoth's routing gives you a clean, clear roadmap everything's gone really well so far: the tuners are installed, the neck is on, the pickups and preamp are in, and the bridge is on. And the electronics actually work!
:headbang:
I looooooooove the neck. The basic tactile experience is pretty fantastic, and being so substantial you really do feel the notes you play. The asymmetric contour is great, too. I do feel like the open pores in the Bubinga can feel a little like they're snags my hand is hitting for lack of a better term, but that effect seems to be going away the more I play, so I reckon it's a combo of wearing away at the edges of the pores and the neck taking on some of the natural oils, etc. in my hand. Or maybe I'm just exfoliating, in a really fun way, lol. I don't know that I'd want to finely sand any further or use wax a la Warwick, but will consider both once I've really spent some time breaking it in.
Plugging in, I'm REALLY happy. The whole spectrum is there, but the midrange is the most clearly defined I've ever had with any bass. Both plugged in and acoustic the piano-like quality a lot of folks strive for is there. Right now I'm just using a single 9-volt with the stock EMG clip; I'll eventually learn to solder effectively, but this isn't the project I want to do that on, lol.
The nut seems slotted really well, Corian gets my seal of approval.
The Hipshot tuners are great, too - I don't have to use a string winder or give myself carpal tunnel to get good string tension, and they're nice and light, which helps since the neck isn't, lol. I didn't realize at the time I ordered the neck that graphite rods were an option over steel, but I've had overall heavier basses with no issues, so I'm not too worried about the weight once I get the strap buttons installed. Right now it balances really nicely on my leg while seated, so it's a pretty safe bet it'll balance well on a strap, too.
As far as challenges, I bought a square jack plate to use, but the roundovers, which are amazing, don't leave enough flat wood to install the square plate flush, so I'm borrowing a football shaped jack plate from my jazz bass, and temporarily have the square one on the jazz diagonally - perfect fit, lol. Pretty silly looking but a workable solution. I also lost one of the screws for the retainer, so I'll probably bring that to Mark (the luthier) when I bring it in for a proper setup and see if he has any spare, and just have him install that. I'd like to say it doesn't need it, but there's just not enough downward tension behind the nut .
To do: Drill for the the jack plate (or maybe I'll just keep that awesome masking tape instead?), battery box and control cover, install the ferrules and strap buttons, wire/solder the battery box to the preamp, and install the string retainer.
