Picklemitts
I'm having a problem with my high E and B strings. They won't sustain like the other strings do. There is a very subtle buzz, and they also sound like they're slightly palm-muted. They just wont ring out like a bell, in other words.
It is not caused by high frets or a bowed neck. I got all of that sorted out and eliminated as a possibility. I thought maybe the string tree placement was pulling the strings over the nut at a funky angle, but I can't make it go away by changing the string angle. Another possibility is that the nut slots are too deep. The strings are sitting where the top of the string is about flush with the top of the nut - noticably deeper than any of my other guitars. It's almost like it was cut for a larger string gauge. It could have something to do with the saddles, too.
Any ideas on how to troubleshoot this? The last couple of problems, which I first thought were manufacturing tolerance problems, turned out to be caused by my impatience when setting it up. I'm sure this will be no different!
