PumpinIron
This is a custom made hollow Stratocaster body that weighs in at 3.4 lbs. The top is Zebrawood and the body is swamp ash. The body has a center block and hollow wings, and is extremely light and airy when you pick it up. The top is routed in traditional Stratocaster style, so that you access the controls through the top, just like you would on any other Stratocaster.
This thing is unfinished and will need to be sanded and painted of course. The small chunks of wood you see around the edges are used to hold the body in place while the CNC machine cuts it. They are easily sanded off during the sanding process.
There is a nice neck cut on the rear so that you can easily access the upper area of the neck.
This is an extremely nice body and will make for a truly unique Stratocaster!
If you're interested, I've got it listed on Reverb here:
https://reverb.com/item/10117007-custom-hollow-stratocaster-body-with-zebawood-top
