reluctant-builder
As a lefty, I always run afoul of a dearth of available instruments to play. This has led me to be adequately proficient at playing a righty upside down and backwards, but I always think: how hard would it be to make a convertible guitar?
The problems, let's just consider hardtails for the moment, are angled bridges and the slots in the string nut.
The adjustable saddles in TOMs allow one almost to convert a righty to a lefty without too much difficulty, but it's never quite enough. So, why not machine an angled bridge whose posts had ovular "washers" ... which would allow one side or another to slide forward or backwards, permitting the user to adjust the slant. Like on a stop tailpiece, there could be little alan key-adjustable bolts to fix it in place once the desired slant was achieved.
This would actually be useful for purposes other than making a bridge lefty or righty. For those of us who like really heavy gauge strings, fixed slanted bridges sometimes still aren't cocked at an angle steep enough to allow proper intonation.
Moving on to the string nut, though ... this is where it gets a little dicier. Most nuts are not symmetrical as a whole, to say nothing of the string slots. A lot that I've seen are flat on the fretboard side and rounded on the headstock side. My Strat has a nut that is pretty symmetrically rectangular, though. In which case, it doesn't seem inconceivable that it could simply be worked out and flipped around, if needed.
Edit: That said, if nuts were made, say, with two little posts in the bottom that fit into small divots made in the neck's trench, they wouldn't necessarily need to be glued in; the string tension would keep it in place and the posts in the divots would aid in it remaining in place if the tension were relieved to adjust the truss rod or change strings, etc... This would make it much easier to just change the nut for one dexterity or the other. /Edit.
There are myriad permutations, I know. Floyds, LSRs ... about the former, I know nothing, as to the latter, I know the ball-bearing position and character of the string slots preclude flipping it. But this isn't a proposal I expect to work in all cases, just some. And it really isn't that inconceivable, to me.
I suppose the bottom line is that it's just not worth the cookie-cutter companies' time and money to develop.
