I recently bought a split Jazzmaster body as my first Warmoth build. It's beautiful and everything, but we're installing the pickup mounting rings right now, and the bottom-right screw holding the ring to the body goes straight through the hole that's drilled for the wire of the pickup. Since the pickup needs to be IN there to mount it, this means that the only option is to screw straight through the wire. We've had to drill a new hole from the pup rout to the control cavity, and since these bodies cost hundreds of dollars, there's no excuse for this to be an issue. For the sake of the customer, please fix this.
